Hi Everyone - I have a question. What is the way that you guys store your Euro Collections? Especially if you are attempting to collect every coin from every country for every year?
Do you use those plastic Euro Sleeves that allow 3 plastic sleeves of 8 Coins to be placed in 1 plastic page,and then stored in ring binder album?
I think that the Numis version is called NH24 as per the one shown on this link
http://www.renniks.com/main.aspx?pageid ... =&pid=4064
Cheers Mike
Euro Albums
- brismike
- Recommendations: 3
Re: Euro Albums
Anyone can answer the above question?
Mike
Mike
- magneto
- Recommendations: 109
- Last recommendation: 07 Jun 2022
Re: Euro Albums
hi mike
some years ago i bought these euro sheets from numis to store many unc euro coins sets i had
but after one -two years the coins begin to loose the shine and even worst, got some strange colors in the surface
one main problem is these sheets is not suitable for unc coins cause they are not airtight and the air can go inside.
also if you put many sets inside the weight of the album is very heavy and not suitable for transport or presentation.
indy19590476
- Recommendations: 207
- Last recommendation: 15 Apr 2016
Re: Euro Albums
Hello Mike,
For me the best solution are capsules, but expensive.
Another solution, are the coin holders self-adhesive, less expensive and perfectly adapted.
What it is necessary to avoid, it is to store these coins in a plastic packaging (humidity = oxidation).
Here is how I collect my BU by Vatican.
Best regards, Indy
Best regards, Indy
- BU Vatican
- Redimensionnement de 04.jpg (39.05 KiB) Viewed 15292 times
- magneto
Re: Euro Albums
i agree indy the best solution is the capsules,
with coin holders self-adhesive if you want to store them for long period, you have periodically to replace them with new-ones cause the glue won't stay for ever.
- luit
- Administrator
- Recommendations: 328
- Last recommendation: 10 Aug 2022
Re: Euro Albums
I use 2 staples in addition to the glue and coins from 2002 are still OK.magneto wrote:with coin holders self-adhesive if you want to store them for long period, you have periodically to replace them with new-ones cause the glue won't stay for ever.
Luit
- magneto
Re: Euro Albums
yes i know luit, still i prefer the capsules
