edit own post
Post your questions, tips, suggestions for the webmaster
Aussiedollar
Recommendations: 147
Last recommendation: 27 Jan 2025
edit own post
Post by Aussiedollar »
Hi folks,
I can't edit post of my own. Has anyone a solution?
It works with Windows Internet Explorer, but doesn't work with Firefox
See you
Aussiedollar
trancemaster2k
Recommendations: 177
Last recommendation: 18 Mar 2021
Re: edit own post
Post by trancemaster2k »
Edit function working fine here using Firefox Portable 10.0 (WinXP).
davidhs
Recommendations: 134
Last recommendation: 06 Apr 2025
Re: edit own post
Post by davidhs »
Using Firefox 10.0 (installed) (WinXP) works fine, also.
Stupid question: Are you log in?
Wanted & swap (euro coins, world coins and banknotes circ) https://goo.gl/AQjfKp
Wanted & swap euro http://euroswapper.nl/viewtopic.php?f=6&t=3263
World CC coins http://euroswapper.nl/viewtopic.php?f=8&t=5298
Aussiedollar
Re: edit own post
Thanks a lot.
Surely I'm logged in :D .
And now I've made an upgrade for firefox 10.0 (by Win.XP) but the same problem. If I use Explorer I can edit my post. I thought it's a new problem, but it seems to be a problem of myself (for remembering: 98 % of pc-problems are caused between chair and keybord :shock: )
See you
Aussiedollar
davidhs
Re: edit own post
Post by davidhs »
I test in my
- PC with WinXP (Firefox 10.0 and Explorer 8.0) and
- laptop with Win7 (Firefox 10.0 and Explorer 9.0)
and works fine in all cases. Before update Firefox to 10.0 I used 9.0.1 and I had not problems.
Perhaps problem is cache? Try clear the cache from Firefox. I do not know...
trancemaster2k
Re: edit own post
I always set Firefox privacy options to NOT save any cookies, NOT use cacheing function/tracking etc.
Maybe you can try to download latest Firefox Portable version,
extract it to a temporary folder and test the editing function of your posts.
If it works there try to change settings on your primary installed Firefox version.
Aussiedollar
Re: edit own post
Now it works :D
Thanks a lot..... I don't know why :oops:
See you
Aussiedollar
